The leak is going down the engine side of the fire wall and on to the floor. I put fluid in it about every two months. Is the Master cylinder leaking into the booster and then to the floor? I thought the master cylinder if it leaked around the seals would leak into the passenger side of the firewall? I assume the master is bad and needs to be replace.
Brake fluid leak around master cylinder - johnbsz10:01:57 05/31/11
